It is currently Sat Aug 16, 2025 7:05 am
 Post subject: Source for veneers
PostPosted: Tue Jun 30, 2015 11:40 am
I'm looking to experiment with laminate and double top archtops and I'm curious if you guys know of a source for veneers. Specifically maple in sizes big enough to do one piece backs etc..
 Post subject: Re: Source for veneers
PostPosted: Tue Jun 30, 2015 1:30 pm
veneersupplies.com perhaps...
PostPosted: Tue Jun 30, 2015 2:22 pm
I should have stated that what I'm looking for is much thicker than most readily available veneers. Most laminate guitars I've seen use stuff closer to 1/16" thick.
PostPosted: Tue Jun 30, 2015 2:36 pm
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
Try certainly wood in Buffalo. They do have a special thickness section on their wood menu.
Typically though most cabinetry veneers are very thin, like 1/42".
PostPosted: Tue Jun 30, 2015 2:44 pm
First name: Heath
Last Name: Blair
City: Visalia
https://www.certainlywood.com
sweat the small stuff.
PostPosted: Tue Jun 30, 2015 9:59 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Did you know you can easily thickness wood to1.6mm on a thickness sander? Assuming you have a good bandsaw. What I can't say for sure that that is economically feasible. I make my own .6 mm veneers that way.
If I had a billet of the wood you were planning to use, I'd resaw it to .15" or so, then use an elevated bed to bring it down to your desired thickness. I wanted African Blackwood veneer for my current bevel project, had to make my own
PostPosted: Tue Jun 30, 2015 10:40 pm
If I could find figured boards at least 17" wide I still couldn't resaw them (my saw doesn't have that kind of capacity). Plus it would be counter productive to reduce 4/4 stock down to 1/16". I'd think somebody has to have this stuff. Gibson, Benedetto, Guild etc. are getting it from somebody. I could easily make book matched veneers but I don't know how well the seem would enjoy being forced over an arched form.
PostPosted: Wed Jul 01, 2015 10:51 am
try PM'ing member Anthony Zlahtic .. he is working on some 335's and bought veneer for that, possibly from Certainly wood ...
PostPosted: Wed Jul 01, 2015 1:16 pm
A seam will work fine. But for full one piece Look for rotary sliced maple. The big three use basswood crossgrain center cores.
Ken
Ken
PostPosted: Wed Jul 01, 2015 2:29 pm
Dan Yeager sold Acme Archtops but I see there is a new owner and the website is still up. I'd call or mail him and see where he gets his stuff.
I have purchased laminated plates from Acme and they are good.
PostPosted: Wed Jul 01, 2015 6:45 pm
I've been buying veneers and other stuff from these folks for as long as I can remember -- I actually purchased my fist set of back and sides and sound board from them decades ago.
http://www.constantines.com/constantineshistory.aspx
Ken Cierp
PostPosted: Wed Jul 01, 2015 7:38 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Well however you go, I'll pass along a tip I learned from bevel veneering. Seems your curved surfaces apply. Should work with seamed as well. Coat back of veneer with even layer of tite bond. Same with guitar surface. Let dry to non-tack (30-40 minutes?) Position pieces and use an iron to bond. If seamed, start at seams. The iron will help mold the pieces. This is a one shot deal. Cannot rework it. But it works. Practice on parts first.
PostPosted: Wed Jul 01, 2015 7:40 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Yes, 0.6 mm maple will curl when glue is applied. But hardwoods like African Blackwood did not for me. And you wood is thicker. And wider.
PostPosted: Wed Jul 01, 2015 8:27 pm
Thanks guys. I'll look into all of those. I've got two more guitars to get out the door before I can start in on this experiment but when I find a good supplier I'll let everyone know.
Users browsing this forum: pkdz and 31 guests
